clean fuel filter swap?
Old Mar 30, 2003 | 04:55 PM
slayer6x6's Avatar
i was told that pulling the connector with the purple, grey and black wires in front of the gas tank releives the fuel pressure so you dont take a bath of gas when you change your filter. is this true, and if so, should i unplug it and let the car run until it looses fuel pressure? thanks!
Old Mar 30, 2003 | 05:43 PM
TheGreatJ's Avatar
That's the fuel pump connector. Unplugging it and then cranking the car will indeed relieve the fuel pressure, but it's still gonna **** a little because even with no pressure there is still some fuel left in the lines. There's no reason not to, but it isn't really required either.
Old Apr 5, 2003 | 03:33 AM
87_camaro's Avatar
No need...
when i changed my fuel filter, i just opened my fuel tank and left it open... so no pressure was in the tank right? but yeah gas still dripped out but not too bad... i think it would have been easier if the whole car was jacked up.... i had my one side up so it dripped out all funny...
but yeah good luck with it.
Danny
Old Apr 5, 2003 | 09:27 AM
1SLOSBC's Avatar
if its an efi car, just push in on the schrader valve on the fuel rails. running your injectors dry is a very bad thing.
and that filter needs to be replaced every 10.000 miles to keep any kind of performance in your car.
my friend has an ls1 car, quit barking 3rd.... we changed the filter and its back to barking 3rd
thank god the filter is ONE easy thing to do on our cars
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
