383 oil pan
Old Apr 3, 2003 | 04:04 PM
stevem's Avatar
383 oil pan
my crank is hitting my oil pan what should i do.
thanks.
Old Apr 3, 2003 | 06:37 PM
Aron213's Avatar
are you sure its hitting the pan? Are you talking about a baffle in the pan? If its just the baffle, you can modify(beat it down) till it stops hitting
Old Apr 3, 2003 | 07:33 PM
stevem's Avatar
i was hitting the baffle but i cut a bit of it out then it was hitting in two different spots on the pan lip.so i heated and beat them in so its all ok now so thanks for your input aron213
Old Apr 4, 2003 | 07:24 AM
Jim85IROC's Avatar
There's no reason why a 400 crank won't fit in a standard oil pan.
Old Apr 4, 2003 | 02:18 PM
Lungz's Avatar
yeah, I ahd a stock oil pan and a moroso, both do NOT hit my crank nor my conencting rods
Old Apr 5, 2003 | 09:35 AM
1SLOSBC's Avatar
this does happen once in a blue moon. an easy fix is to use the one piece rubber steel shimmed gasket.
some of the aftermarket "cheap" pans do it....
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
