Charging system problem??
Old Sep 1, 2007 | 06:03 PM
scooters97ss's Avatar
The "new" car stopped charging about 30 miles from home in the pouring rain last night. We made it to the end of our street before it finally died. I replaced the battery with a known good one; removed, dissasembled, tested and reassembled the alternator. Then I put that alt. on my truck. It charges fine. Put the truck alt. on the car, no charge. Car is a 1990 IROC 305 TPI.
I have checked all the fuses with a test light including the one underhood for the fans. I have battery voltage at the back of the alternator. I have also since taken the alternator apart and checked it out then reassembled and put on my truck, it charges mint. I checked all the fusible links and wiring under the hood to and from battery, starter, alternator, relays etc. I am getting frustrated here. Any ideas? (Besides rolling it into the lake.)
Old Sep 1, 2007 | 08:42 PM
n2ceptor's Avatar
With the engine running at idle, are you getting 13.8~14.2 volts at the battery???
Old Sep 1, 2007 | 09:03 PM
No. The alternator is not charging at all. The battery just runs until the voltage is too low and the engine eventually dies.
Old Sep 1, 2007 | 09:35 PM
n2ceptor's Avatar
You might have a fusable link that bad???
Old Sep 2, 2007 | 04:59 AM
I checked all of the fused links with a meter and they test ok.
Old Sep 2, 2007 | 11:40 AM
Mr. Wolf's Avatar
this happend with my 87 a couple years ago and turned out being the wrong connector on the alternator or somewhere along those lines.
Old Sep 2, 2007 | 09:54 PM
It crapped out as we were driving though. It worked ok for the first 1000 miles and quit for the last 30 or so.
Old Sep 3, 2007 | 12:50 PM
Mr. Wolf's Avatar
yeah thats what mine did. ***** up and take her to an electrical shop
Old Sep 3, 2007 | 06:48 PM
No way. I found the problem this morning. Brown wire to the regulator was broken inside the plastic loom where a previous repair had been made. Eastbound and down again!! Yeehaw!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Zomie
Sep 2, 2002 09:04 PM
