car dies under accleration
Old Feb 7, 2007 | 09:12 AM
foxbodykiller's Avatar
ok i have a 1991 z 5.7 auto and when i acclerate the car bogs down and then dies out. does anybody know what this prblem is? thanks in advance for the help.
Old Feb 7, 2007 | 05:16 PM
ws6transam's Avatar
There's not enough information to go on in order to "know what the problem is". So let's guess.
If it idles okay and runs around okay under light throttle, I'd guess you have a fuel delivery problem such as a clogged fuel filter and under high loads, the fuel demand is greater than the pump's ability to shove it through the filter. The engine leans out then snuffs the fire.
That's WAG # 1.
Check your filter and fuel pump. Measure fuel pressure at the rail while under load, if you can.
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
