Is this cam overkill in a 85 l98
Old Sep 27, 2003 | 03:56 PM
jbbiggs's Avatar
I plan to switch to a roller in my tpi, will this need a new chip? idle?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2433915101
Old Sep 27, 2003 | 04:11 PM
Dirt Reynolds's Avatar
236/236 114 lobe sep angle....
If you have a stock engine otherwise, I would not use that cam. It's fairly aggressive but you need a shorter runner intake to use it in the higher RPM range it is designed for, and a higher stall converter. Ported heads would help a lot, also. Your stock L98 is torque biased down low due in large part to the long TPI runners. Installing that cam in a stock L98 is not a good match. Looks to me like it was used in a 383 stroker engine, as it says 'small base circle'. In that application, it would be more appropriate for a street car as the longer stroke can use more duration.
Old Sep 27, 2003 | 04:20 PM
jbbiggs's Avatar
Any suggestions, I have it apart now and have ported the heads, Was considering the powermax 2040 or a zz4 ???????
Old Sep 30, 2003 | 07:37 PM
jbbiggs's Avatar
TTT anyone..................
Old Oct 1, 2003 | 03:51 AM
ZZ4 cam would be a good choice, if you are going to keep your stock TPI induction with the stock or larger aftermarket runners.
Old Oct 1, 2003 | 09:48 AM
Jim85IROC's Avatar
too much duration for the amount of lift. Plus, for the massive expense required to convert an old block to use a roller cam, it's a complete waste. Just buy a nice flat tappet cam for $150 and be done with it.
Old Oct 1, 2003 | 09:26 PM
aklim's Avatar
I used the Accel 74219 cam but if you call Lingenfelter, they will probably advise you on another cam unless you want to do future mods.
Old Oct 2, 2003 | 10:02 AM
Jim85IROC's Avatar
all you guys are rattling off roller cam combos. That's great if you've got a roller block, but to convert with aftermarket roller crap is worthless unless you've got a combo so extreme that you're going to actually realize a horsepower benefit from the roller grinds.
While TPI does seem to work better with a roller grind that slams the valves open and closed faster, unless you're dealing with a pretty wild combo, you're probably not going to get more than a couple extra horsepower by using a roller setup. Unless you're beginning to be using a cam that's wild enough to be pushing the envelope for a flat tappet setup, you're just pissing money away.
rideordie
Nov 5, 2019 04:52 PM
Queens94z28
Nov 20, 2014 06:03 PM
Chris Ja
Aug 1, 2002 07:30 PM
