caliper problem
Old Aug 20, 2003 | 11:38 AM
IROC350's Avatar
caliper problem
my year iroc came with 2 style calipers: cast iron and aluminum. the aluminum caliper is dual piston. the calipers on my car are finned aluminum calipers except that they only have 1 piston. i'm so confused. i've been told they are not 1LE and i'm pretty sure they're not cast iron (they didn't look like the picture i was shown). will the dual piston caliper replace the single piston caliber without having to change too much, ie. rotors, brake lines? also, what kind of caliper DO i have??
Old Aug 20, 2003 | 01:44 PM
87DJP2001's Avatar
The only car to get front (2) piston aluminum calipers were the 1LE Cars, which I think you do not have.
Stock four wheel Disc brake cars before 1989 had front/rear 10.5" rotors with cast iron calipers and single piston.
Later cars starting with 1989 had 10.5" front rotors and cast iron calipers with single piston & the rear had 11.655 rotors and Aluminum PBR calipers with single piston. Again this is for a stock four wheel disc brake car. These same rears came stock on the 1LE cars also.
Old Aug 20, 2003 | 10:59 PM
IROC350's Avatar
yes, my year iroc came with aluminum calipers. but advanced auto parts gave me the 2 piston caliper...not the single piston. she entered the info into the computer correctly too? i'm just confused on why i got the 2 piston when my car has the single piston?
Old Aug 20, 2003 | 11:06 PM
IROC-T's Avatar
Does the caliper mount the same? If it does swap both of them (fronts or backs)out to the twin piston.
T.
Old Aug 21, 2003 | 07:00 AM
87DJP2001's Avatar
Only 2-piston caliper is the front 1LE one and it will not bolt up on either the front or rear mounting brackets. Not the first time a parts store made a error on this.
Old Aug 21, 2003 | 09:30 AM
IROC350's Avatar
i'm gonna take it back today and ask if they haev the single piston one. i may just take the 2 piston one back and wait till i get my caliper off to show those bastards what its supposed to look like
Old Aug 22, 2003 | 09:25 AM
IROC350's Avatar
i knew there wasn't something right with my order. i went back up to advanced and told her i don't think i have the right caliper, i need a single piston one. she looked it back up and said, "ooops, we gave you the front one, ha ha ha." ya, laugh it *****, now i gotta wait till saturday to pick it up. oh well, its all good now, my caliper is coming in, and after a year, my iroc will be back on the road
carguy0119
Apr 11, 2016 11:11 PM
Fastbird93
Apr 9, 2016 07:01 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Z-rated97
Mar 29, 2015 11:17 PM
FirebirdGT
Dec 13, 2014 10:25 PM
