Gauge Swap
Old Aug 21, 2003 | 09:38 AM
jdbrowning's Avatar
Gauge Swap
I was wondering if anybody could assist me here. I have an 84' camaro that just has the standard gauge cluster (speedo, fuel, and the rest are idiot lights) and I am wanting to swap these out with a set of gauges out of an 84'z and I was just wondering what I actually need to make this work. Will my sending units and wirring harness work or do I need the ones out of the Z. PLEASE HELP!!
Old Aug 21, 2003 | 10:26 PM
m0nk's Avatar
I changed clusters in an 87, from the speedo/gas w/ idiot lights, to speedo/tach w/ all guages. Guages worked fine and everything, But you need to make sure the guages that you get were from a car w/ the same amount of cyls that you have. A v6 guage will not work w/ a v8, at least not to my knowledge.
Old Aug 22, 2003 | 08:20 AM
jdbrowning's Avatar
Monk, Thanks for the info. Did you re-use your existing sending units and everything or did you have to replace all of that as well. I currently have a 305 in the car now so both engines are the same
Old Aug 22, 2003 | 01:45 PM
gfrankel's Avatar
all you need is teh gauge cluster, oil pressure, and water temp sending unit. It should just plug right in.
Old Aug 22, 2003 | 02:07 PM
chevyman502bb's Avatar
how about taking the stock tach out and replacing it with an autometer 5' tach? if it cant be done im still gunna get a tach w/ shift light for the dash or somn.....but i might need to replace the stocker anyways cause its stuck at about 2500 (keep in mind i dont have the motor in it right yet)
zxtce
May 7, 2015 08:53 PM
nosliw
Apr 27, 2015 04:01 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
mackirockz
Feb 4, 2015 07:03 AM
