A/C and SMOG pump DELETE PULLEYS
Old Oct 4, 2003 | 10:19 PM
  #16
Dave89IROC's Avatar
Re: smog pump removal
Originally posted by citizendan1st
HEY EVERYONE...
I recently had my bypassed and gutted smog pump bearings lock up...have to replace or remove.I have an 88 305 tpi serpintine with ac setup..
when i removed the smog pump i tried a shorter belt.When i released the tension..it pinched the belt in between the ac and other pullys. I hd to buy a new smog pump for 60 bucks.I cant wait till monday for a used one from one yard.And i dont even use it. Plus the old pully bolts wouldnt work on the new pump so i spent half the day looking for the right bolts. {THey were 8 mm by the way it any one needs to know}. But if i could still remove it please share the info. I would love to free up the horsies.
Thanks again..
Dan Egger
go here
http://www.thirdgen.org/newdesign/tech/serpentine.shtml
to eliminate the smog pump
Old Oct 4, 2003 | 10:21 PM
  #17
Dave89IROC's Avatar
you could get rid of A/C and the smog pump if you could find a tensioner that tensioned the other way, on the inside (ribbed) of the belt
Old Oct 8, 2003 | 11:37 AM
  #18
FSTFBDY's Avatar
Just goto the link I posted. You can get rid of em both ac/smog and reverse the way the tensioner pulls.
HarleyZ28
Oct 5, 2015 06:23 AM
alphaauto
Jan 23, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:34 PM
rje
Sep 9, 2002 12:35 PM
Timberwolf
Aug 9, 2002 11:24 AM
