i need help badddddddd
Old Oct 7, 2003 | 08:19 PM
Irocdriver89's Avatar
Unhappy i need help badddddddd
well after finally finding out what engine is in my car I need hhhhelp
the car would not start so i had to push it out of the paint booth. i dropped the rear and put 1- new fuel pump, and the pump would not come on when i turn the key. 2- fuel rely, they said it my not be getting power because of the rely but that did not work. 3- a hot wire to the switch at the top of the pump right under the back carpet, but that just dumped gas out my cat which is the last of my piping (while in paint did not want paint on the tips or piping) 4- Now i have a hot wire running to the rely and it seems to control fuel flow, but now the car won't idle you start it and it dies. when you hold the gas down the car will run, but don't let go or it dies. one time it did idle but up and down from 500 to 1,000. make a sharp turn or press the brake hard and it dies but will fire right back up. put new plugs also today and am working on changing the wires.
help it looks good and i can't even drive it new paint is
orange.
Old Oct 7, 2003 | 09:23 PM
kevin 2.8's Avatar
so what engine is in it and is it carbed or tbi or tpi?
check coil
Old Oct 7, 2003 | 09:27 PM
Kuruption562's Avatar
i seem to be having the same problem. it started dieing 3 days ago. i hate that ****t
Old Oct 7, 2003 | 09:31 PM
FishPig's Avatar
also check your fuel filter. You say you get gas when you stomp on it but otherwise it dies. you probably have either a clogged filter or a clogged fuel line....(at max pressure it works) Since you have it painted you might also want to change your air filter. You may have it clogged also from the paint both???
Old Oct 7, 2003 | 09:49 PM
lordmetalz28's Avatar
please dont tell me you have to drop your entire rear to get to the fuel pump. please dont say that.
Old Oct 7, 2003 | 10:40 PM
Wardo's Avatar
If it pumped the motor full of enough fuel for it to come out the cat, please tell me you changed the oil before you got it running at all.
Old Oct 7, 2003 | 11:45 PM
Willie's Avatar
Re: i need help badddddddd
....the car won't idle you start it and it dies. when you hold the gas down the car will run, but don't let go or it dies. one time it did idle but up and down from 500 to 1,000. make a sharp turn or press the brake hard and it dies but will fire right back up.
This is exactly the symptom when the MAF dies. Disconnect the MAF and start the engine. If it continues to run, the MAF is most likely dead. But before you replace this rather expensive sensor, replace both the MAF power and burnoff relays. They're very inexpensive compared to the MAF and could also be the problem.
Old Oct 7, 2003 | 11:57 PM
where is the MAF located?
Old Oct 8, 2003 | 12:03 AM
Willie's Avatar
I'm assuming you have a TPI? If so, the MAF is a black, 3-inch diameter sensor that's about 4-inches long. It's located between the "Y" air intake and the accordion-looking inlet in front of the throttle body. The connector is located on the bottom. Be careful when disconnecting it. Make sure to use a screwdriver to lift the retaining clip, then pull the connector out straight towards the back of the car.
Also, when running the engine with the MAF disconnected will result in an SES code. Disregard this as running without the MAF is only a test. Once you shut the engine off, remove the ECM power fuse for a minimum of eight seconds. Then reinstall it. This will clear all codes. The power fuse is located in-line in a black plastic fuse holder bolted (one 7mm sheet metal screw) to the passenger side fender in front of the coolant overflow reservoir.
Willie
Old Oct 8, 2003 | 01:08 AM
90rocz's Avatar
If there is water in the fuel tank it will slosh up into the pump, "when you brake hard, or make a sharp turn".
Old Oct 8, 2003 | 11:07 AM
aklim's Avatar
But of course you do.
Old Oct 8, 2003 | 11:25 AM
Thumbs up
thanks this is great help i will try everything possible and let you guys know what works and if all else fails there will be an iroc for sell............oh my engine is a 350 crate motor and it has tpi injection i found out the original motor blew a head gasket. when it had just come out of warrenty and he but a crate in to replace it thanks john. so my new tag will be irocdriver89 350tpi thatsounds great if i can ever get the car going again.
Old Oct 8, 2003 | 12:32 PM
efizjb's Avatar
You might want to check for loose grounds, especially if the motor was replaced, many of the swithcing grounds from the ecm and relays ground on the back of the cylinder heads. Check the connections on the back of the cylinder heads above the trans bellhousing, the factory harness has multiple grounds tied together to a ring terminal that bolts to the cylinder head. You could have a loose ground thats affected when you turn etc.
Old Oct 8, 2003 | 03:46 PM
Z28James's Avatar
Ive had so much fun undoing all the half-*** work the guy before me did when he dropped the engine back into my car after it was rebuilt. Not to mention undoing the genius work like taking out the windshield washer fluid tank, etc. Who needs clean windshields anyways? Engine does look nice...ill give it that....tranny does throw you back when it shifts from 5000rpms as well so i guess its not all bad
