a/c deletion
Old Dec 31, 2003 | 02:14 PM
dailydriver's Avatar
a/c deletion
In taking our the air conditioning system, what are the challenges I can expect to face or things i should be aware of beforehand??
Old Dec 31, 2003 | 03:04 PM
dj haf's Avatar
not that hard... u just need to remember you need an a/c delete pulley to put in place of the a/c compressor
Old Dec 31, 2003 | 03:33 PM
dj haf seen a few mentions of smog pump being deleted, what exactly is the smog pump and where can i find that on my car?
Old Dec 31, 2003 | 06:07 PM
dj haf's Avatar
removing the smog pump (it's a pulley under the ac compressor) just frees up some room in your engine compartment... i dont think it'll give you much power, atleast you won't notice it... 2 hp to the wheels maybe? lol
btw... why are you taking out the ac?
Old Dec 31, 2003 | 09:49 PM
97WS6SCharged's Avatar
Cause he doesn't live in FL where the summer temps top 100 degrees.
Old Dec 31, 2003 | 11:23 PM
Rage's Avatar
Does your a/c system work? If so, shoot me a price.
Old Jan 1, 2004 | 02:00 AM
dj haf's Avatar
take out the smog pump and all the equipment, put a a/c delete pulley, and get a march crank and alt pulley and you'll gain about 10-20 hp from this... you'll notice a difference
Old Jan 1, 2004 | 07:15 AM
Brit Iroc's Avatar
....and take a bit of weight off the front end.
Old Jan 1, 2004 | 11:46 AM
CamaroZ28Coupe's Avatar
what if you got v-belts, then you dont need any pullys or anything right? becasue i have an 83 lg4 and i have v belts,
so if i wanted to i could bassically just cut the a/c belt off if i wanted to?
or would i need to adjust tension on the other belts to even things out?
Old Jan 1, 2004 | 11:54 AM
Brit Iroc's Avatar
In that case just take the belts off the a/c and the smog pump and you are done.
Old Jan 1, 2004 | 03:07 PM
dj haf's Avatar
i hope your not doing this to free up power... i'd understand if you had an 10 second car... but why would you wanna give up A/C if your still gonna be slow? you know? it wont do much for ya
Old Jan 1, 2004 | 04:14 PM
Brit Iroc's Avatar
Like a t/body airfoil you mean?.
Old Jan 1, 2004 | 06:52 PM
dj haf's Avatar
t/b air foil? lol i paid a dollar for mine... atleast now my t/b looks cute lol
Old Jan 2, 2004 | 04:52 AM
whats up,
the reasoning behind taking out my a/c is that i never use the a/c, and secondly i've read theres a good amount of weight in that system near 70lbs, to reply to rage, yes my system does work, its not the coldest a/c in the world but yes it does work fine, email me if you are serious about it....i figure with the one pulley freed up, the 70lbs gone and all that space opened up it would just be better.
and you said the smog pump is pulley driven?
again appreciate the advice and info
Old Jan 2, 2004 | 12:13 PM
Craz-28's Avatar
Tell you one thing though, after you remove it, changing sparkplugs and even installing headers will be SOOOOOOOOO much easier.
