Bolts Busted...............
I had some bolts bust when I was removing my crossmember, and am unsure how to remove them. Any one else out there had to tackle this problem? Any info is appreciated....Thanks
If any of the bolt is exposed then a pipe wrench can grip it. If not you have to drill into it dead center and use a quality easy out. The autozone ones tend to break. Get the ones at a tool shop. Worst case is drill it all the way to the threads and tap hole. I've been fortunate enough to not have to use that option.
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
