Bogs, misses after 3000 rpms
Old Mar 16, 2004 | 12:01 PM
kbog54's Avatar
Hey, i just took my 83 Z (305) out for a little drive the other day and when i rev it up past 3000 rpms while idling or driving it starts to miss really bad. I'm getting a code 42 or 43 (cant remember) I just got a heated o2 sensor (i just put lt's in) so i'll see if that makes a difference.
any ideas as to what could be going wrong?
Old Mar 16, 2004 | 12:31 PM
PyRo9862's Avatar
42. Fault at electronic spark timing circuit OR
Fault at direct ignition system OR
Fault at fuel cutoff relay circuit
43. Low voltage at electronic spark timing circuit
Pull the codes again, and remember this time, then you will have a starting point.
Old Mar 16, 2004 | 03:05 PM
kbog54's Avatar
Any idea what would cause this?
Old Mar 16, 2004 | 04:55 PM
kevin 2.8's Avatar
coil, cap and rotor, spark plugs, wires
Old Mar 17, 2004 | 11:55 AM
kbog54's Avatar
I just replaced the coil, cap, rotor, plugs and plug wires. basically everything except the ignition module.
I found out that my battery was bad- it wont hold a charge, would this cause my problems?
Old Mar 17, 2004 | 02:31 PM
PyRo9862's Avatar
Doesn't the ignition get all its power from the alternator once its started? Change the battery if its bad and see if that fixes anything, you need to do it anyway. Your sure its your battery not holding a charge, and not a bad altenator right? I doubt all your wires or plugs would have went bad at once, you probably didn't need to do those.
Have you pulled the codes again yet to determine what is wrong?
PyRo9862's Avatar
Old Mar 17, 2004 | 08:47 PM
aklim's Avatar
Re: .
Diagnostic is hard to perform without being able to rule out as many things as possible. Fix battery first and see if that helps. My old car died because the alternator was not charging the battery and it slowly wound down.
MichiganSkip
Jun 8, 2015 10:30 AM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
Redbird
Sep 15, 2002 07:41 AM
3FifteenPlus
Aug 5, 2002 11:42 PM
