Best way to ! Knock sensor
Old Jul 15, 2003 | 06:37 PM
funina91ss's Avatar
I have a hard hitting clutch and loud eqhast on my 91. I was wondering what is the best way to ! the KS on my 305 TBI.Thanks Sean
Old Jul 15, 2003 | 06:41 PM
Chuck!'s Avatar
I wouldnt get rid of it, the 350 knock sensor is less sensitive that might solve your problems.
Old Jul 15, 2003 | 06:43 PM
funina91ss's Avatar
I know it has never had any real knock I run 94 octane in it and it only shows KN. when I shift gears real hard with the cutout open.I just want a simple way to disable it.Cheap too.
Old Jul 18, 2003 | 04:34 PM
Slow91z's Avatar
Like the man said use the less sensitive one...The problem is you never want it until you crack a piston...
Old Jul 18, 2003 | 06:41 PM
Damon's Avatar
If you really want to delete it here's how:
Buy a 25 cent 3900 ohm resistor from Radio Shack. Run the KS wire to one side and attach the other side of the resistor to a good ground. Done. ECM will think it's still there (no check engine light) but, obviously, it won't ever hear engine knock again.
Why it works: the ECM only knows the KS is there by checking resistance to ground through the KS wire. The stock sensor happens to be about 3900 ohms. Check it with an ohmmeter if you want to convince yourself.
Old Jul 18, 2003 | 06:42 PM
funina91ss's Avatar
Thank You thats what I wanted to know....I might put it on a toggle to keep some of you guys happy...
Old Jul 18, 2003 | 06:54 PM
Damon's Avatar
That's funny- I did EXACTLY that on a car once. Run the KS on the street like normal, then switch it over to the resistor when going racing. You need an SPDT switch (also available from Radio Shack). Single Pole, Double Throw. If you don't get a weatherproof one it'll start getting "flaky" on you within a year. Ask me how I know!
Also, on most SPDT switches the poles it connects are the OPPOSITE of the direction you flip the switch. Ask me how I know that one, too!
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
