Best head/cam setup
Old Oct 25, 2007 | 04:59 PM
output's Avatar
Best head/cam setup
What should I run head wise for my 1985 camaro. It's running a 1979 350 4-bolt main with an elderbrock intake and carb (4-barrel) and it has a very mild elderbrock cam and stock heads. What heads/cam should I be looking at to get to my 400 hp goals naturaly aspirated?
Old Oct 25, 2007 | 08:11 PM
toby's Avatar
what kind of a budget you are working with would be helpful. which edelbrock intake are you using?
Old Oct 26, 2007 | 05:08 PM
output's Avatar
Not really sure how much im going to have to put out. How does $3000 sound for a start on the head/cam? this project isn't ganna start until next year but im making santa a list starting now.
any infromation is great and helpful thanks
*EDIT*
Not sure what it's running for the intake. I will take pictures of the carb and manifold soon and post
Old Oct 27, 2007 | 08:55 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
The best heads out there are either the Trick Flow 195's or the AFR Eliminator 195's.
For camshaft, sorry I dont know flat-tappets, only rollers. The XFI268HR-113 is one of the best.
Old Oct 28, 2007 | 10:27 PM
confused327's Avatar
You can't go wrong with the Trickflows or the AFR's. That said, I love my Trickflows!
Old Oct 29, 2007 | 08:06 AM
Marc 85Z28's Avatar
$3000 will go a long way. For that budget go with a set of AFRs new 195 Eliminators milled for better compression, Edelbrock Performer RPM intake fed with a 750cfm carb, and if staying flat tappet go with a Comp Xtreme Energy 274 or 284. Your budget should allow for a hyd. roller retrofit, which I would highly recommend for all sorts of reasons.
Old Oct 29, 2007 | 01:40 PM
Rice Killer87's Avatar
Absolutely ^ .
You could buy a set of vortec heads and make 400HP and their not even a grand ready to go.
http://cgi.ebay.com/ebaymotors/High-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Vorte...QQcmdZViewItem
Old Oct 29, 2007 | 08:52 PM
AutoRoc's Avatar
SDPC2000.com has Vortec top end kits ready to go for .575" lift cams. Heads/cam/intake/carb for a good price. It will be close to 400hp with accessory drives, etc on the engine. retrofit lifters, goodpushrods, etc will add to that cost..goodluck!
If you want a lot more than 400hp, go with AFR 195 Eliminators, super victor intake, a lot more roller cam, etc...a stock bottom end MIGHT live at a high rpm making big HP but t also MIGHT NOT live...
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
