Best head/cam setup
Best head/cam setup
What should I run head wise for my 1985 camaro. It's running a 1979 350 4-bolt main with an elderbrock intake and carb (4-barrel) and it has a very mild elderbrock cam and stock heads. What heads/cam should I be looking at to get to my 400 hp goals naturaly aspirated?
Not really sure how much im going to have to put out. How does $3000 sound for a start on the head/cam? this project isn't ganna start until next year but im making santa a list starting now.
any infromation is great and helpful thanks
*EDIT*
Not sure what it's running for the intake. I will take pictures of the carb and manifold soon and post
*EDIT*
$3000 will go a long way. For that budget go with a set of AFRs new 195 Eliminators milled for better compression, Edelbrock Performer RPM intake fed with a 750cfm carb, and if staying flat tappet go with a Comp Xtreme Energy 274 or 284. Your budget should allow for a hyd. roller retrofit, which I would highly recommend for all sorts of reasons.
Absolutely ^ .
You could buy a set of vortec heads and make 400HP and their not even a grand ready to go.
http://cgi.ebay.com/ebaymotors/High-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Vorte...QQcmdZViewItem
SDPC2000.com has Vortec top end kits ready to go for .575" lift cams. Heads/cam/intake/carb for a good price. It will be close to 400hp with accessory drives, etc on the engine. retrofit lifters, goodpushrods, etc will add to that cost..goodluck!
If you want a lot more than 400hp, go with AFR 195 Eliminators, super victor intake, a lot more roller cam, etc...a stock bottom end MIGHT live at a high rpm making big HP but t also MIGHT NOT live...
detroitmuscle
Jul 31, 2015 04:21 AM
