Best cam for HSR
Old May 1, 2004 | 01:57 PM
  #16
RedIrocZ-28's Avatar
I'm going with a custom grind cam cam, Already installed HSR, and AFR 195's.
I'm in the 228/234 range with some cool lift numbers, nothing high or anything... think "close to LT4 Hot cam."
Old May 1, 2004 | 02:09 PM
  #17
mrr23's Avatar
look at www.stealthram.com and see what everyone else is using with their HSR.
Old May 2, 2004 | 01:41 PM
  #18
305RSlc's Avatar
when I build mine I'm going with a HSR and the GMPP 350 Hi-Performance cam. Has something like 236/244 duration @ .050 and some great lift numbers. Of course I'll be running a T56 with 4:10 gears. The HSR likes breathing up high so something with at least 220 duration would be good.
Old May 5, 2004 | 12:26 PM
  #19
aklim's Avatar
Going to use a cam where the specs will be 230/236 - 110 lobe sep, 108 intake centerline (2 deg. advanced). Lift with 1.6/1.5 rockers is .622 / .570". 42 pph injectors with 3800 stall and 3.73 gears with the HSR.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
