Beefing up the 10-bolt
Old Oct 5, 2003 | 11:29 AM
Black6SpdTA's Avatar
Red face Beefing up the 10-bolt
With all my talk about a 9-bolt swap, I may just beef up the 10-bolt. I've been looking at 2 parts:
SLP Take Off- http://www.slponline.com/view_produc...&SHOWEMAIL=Off
Thunder Racing "Complete Gear Package" - http://www.thunderracing.com/index.c...ategoryid=1062
$100 for the posi and $400 for the gear package.
I need someone to explain carriers/series to me. A carrier is the center section ("pumpkin") correct? If I get 3 series gears and a 3 series posi will it all fit in my 3.08 Open 2 series carrier? Thanks!
-Rippin
Old Oct 5, 2003 | 11:45 AM
Dave89IROC's Avatar
the carrier is the actual posi......... http://www.slponline.com/view_produc...&SHOWEMAIL=Off
there are series 2 and 3 (for normal people, there are probably others for extreame gears)
serires 2 is 3.08 and lower(number), series 3 is 3.23 and higher(number)
all you need to change a series is the carrier and gears(and assosiated bearings, ect.,)
also, for even more durability, you may want a T/A cover and a solid pinion spacer when you get all this installed
StealthElephant's Avatar
http://www.ws6transam.org/10bolt.html
Old Oct 5, 2003 | 11:51 AM
Originally posted by Dave89IROC
You may want a T/A cover and a solid pinion spacer when you get all this installed
The kit from Thunder I was talking about includes the cover. Is the Solid Pinion Spacer a replacement for the stock Crush sleeve?
-Rippin
Old Oct 5, 2003 | 12:00 PM
Dave89IROC's Avatar
-Rippin
yes, and when installing, shims are used to set preload, not the crushing of the sleeve
Lous69
Mar 19, 2015 10:20 AM
TitoPR221
Jan 29, 2015 08:00 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
CamaroBoy96Z28
May 14, 2003 09:37 PM
RedScreamin
Feb 12, 2003 12:53 PM
