Back seat keep or lose
Old Feb 17, 2004 | 07:48 PM
8_4_berlinetta_'s Avatar
Im in the process of redoing my interior and i was thinking of shaving all the mounts for the back seat off
what do yall think??
Old Feb 17, 2004 | 09:31 PM
Blown350ZZ4's Avatar
depends if you ever put anyone back there. Within the 7 years that I had my third gen, I can cound the number of times I have put someone back there on one hand. That is why the back seat is usually just folded down.
I would say keep them there unless you have plans of putting something cool back there. For example, 2 ten lbs NOS bottles or some kick *** amps.
Nick
Old Feb 17, 2004 | 10:26 PM
KnightRider350's Avatar
Anyone have pictures of cool stuff for back there? I'd like to see how someone would mount nitrous back there.
Old Feb 18, 2004 | 07:22 PM
Ville H. Valo's Avatar
Replace your seats with forth gen leather seats.
- Ville
Old Feb 19, 2004 | 12:22 AM
irocz2804's Avatar
that is what i want to do but they are kinda expensive...and i just had to buy new tires
Old Feb 19, 2004 | 09:25 AM
doug791's Avatar
pull them out right now! Personally i hate taxing people around if i wanted to drive people around i would have bought a van. This is the reason my seats came out however now that they are out im so glad i did it. The brackets sticking out from the carpet dont look fantastic but the car as a whole looks sooo much more sporty as a 2 seater. Also i plan (when i can get the money together) to put a roll cage in so the back seats would have been coming out at that point anyways. I already promised some pics of the back seats out to someone on tgo so ill get em taken and put em up in the next day or 2
Old Feb 19, 2004 | 10:09 AM
I got half of my back seats removed... *chuckles* I think I got the bottoms out, but the tops required a torx bit, which I don't have. :P Too lazy to borrow one. Ah well, come summer I'll finish that project off.
Old Feb 19, 2004 | 01:30 PM
f-bodybuilder's Avatar
How heavy are the back seats anyway?
Old Feb 19, 2004 | 01:43 PM
transxtreme's Avatar
Heres what i did to turn my IROC into a 2 seater. I put my amp on a custom rack in the storage area. I made the wires from the amp to my box long enough to reach to the back seat. I fold down my back seat and put the box on top of it. It works real well and it looks awesome with huge subs right behind your seat. But when i need to carry some extra hoes (haha) i can move the box back ontop of the fuel tank hump. It works great either way. Maybe later ill make a custom fiberglass sub enclosure and take out the back seat for good.
Old Feb 19, 2004 | 03:13 PM
doug791's Avatar
They weigh absolutly nothing theyre foam. Your not gonna save much weight on this one.
Old Feb 19, 2004 | 08:53 PM
Black6SpdTA's Avatar
I read they were ~30lbs? I think it was on that weight reduction article on TGO. Either way, it does look a lot better without them. I'm with you Doug, a cage! I'd like to cage her and have just one 10-15lb N20 bottle mounted in the center. Talk about P-I-M-P
Old Feb 19, 2004 | 09:57 PM
doug791's Avatar
yup 6/8 point cage, nitrous bottle mounted on the drive shaft hump, 2 10" subs either in the trunk or behind the back seats, and almost completly gutted interior, thats the plan at least
as for em being 30 pounds total i doubt that highly but id say maybe 15-20 theyre just foam padding but obviously they have some weight. Not enough to make any difference from removing them tho
Old Feb 20, 2004 | 02:07 AM
kandied91z's Avatar
i would think a good 25lbs is expectable however it take 100lbs to shave .1 off your time so i wouldn't do it expecting to be speed racer.
i recently removed mine for good, i wouldn't recommend doing it unless you have something some how to replace it though as i personally think it looks funny with a big hole and nothing to fill it and since the seats are that heavy it's not worth it in my opinion over looks.
i recently installed a 6pt. chromoly cage with some corbeau seats and a 3,000 watt system so i decided to ditch the seats. i'm currently finishing my custom setup but the 3 10" subs reside basically where the top of the rear seat sat, i used the stock seat brackets as mounting points for my enclosure which came in handy. beneath the custom box setup i have two nitrous bottle that are angled towards the center console mounted to the rear hump. using some creativity and alot of leather i was able to wrap everything up nicely. this way i can turn my bottles on very easily, it's hidden from view for the most part until you turn the disco ball on and it all works together so there isn't just a big hole.
if you want to remove the seats you should, i just wouldn't recommend it unless you have plans to fill it as the weight reduction really doesn't justify the bad looks. i would not remove the brackets though as you never know if you want to put the seats back and they aren't noticeable enough to others to warrant cutting them out for good. however its just my opinion.....
good luck!
Old Feb 20, 2004 | 12:00 PM
aklim's Avatar
I don't know about the weight of the seats but I would say the foldable part and the foam stuff might not be that bad to leave there from a traction standpoint. In any case, I would probably remove it if I was installing a roll cage.
cmyname1
Feb 19, 2015 08:38 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
firebirdude
Aug 7, 2002 07:31 AM
dmaastr
9
Jul 1, 2002 02:22 PM
