APFR setting question????
Old Apr 30, 2003 | 10:02 PM
2FAST4YA's Avatar
Recently I was at the track for a little T&T and I was running low 14's with bad 60 ft times, but anyway I checked my APFR gauge and it was at 55psi when I disconnected the vacum line. My question is this setting to high and could I see more power if I set it lower and to what?
Old May 1, 2003 | 06:54 AM
jzajac1's Avatar
If your running a lightly modified or stock engine, you don't need 55 psi. It won't hurt anything but it does make your pump work harder. I'd set back to a max of 50 psi and leave it alone.
Old May 1, 2003 | 07:15 AM
irocz8957's Avatar
i would leave it at about 50 psi no more than that!
Old May 1, 2003 | 07:07 PM
2FAST4YA's Avatar
Will do, thanks for the info guys,
Old May 2, 2003 | 02:00 PM
aklim's Avatar
I made some comments here: http://web.camaross.com/forums/showt...hreadid=114405
Also, I'd go back to stock and then work your way up. Remember, you have 24 pph injectors when the stock is set up for 22 pph. You are already running richer unless you have done something to the EPROM we don't know about.
HectorM52
Jul 30, 2017 11:46 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
