APFR setting question????
Recently I was at the track for a little T&T and I was running low 14's with bad 60 ft times, but anyway I checked my APFR gauge and it was at 55psi when I disconnected the vacum line. My question is this setting to high and could I see more power if I set it lower and to what?
I made some comments here: http://web.camaross.com/forums/showt...hreadid=114405
Also, I'd go back to stock and then work your way up. Remember, you have 24 pph injectors when the stock is set up for 22 pph. You are already running richer unless you have done something to the EPROM we don't know about.
Chris Anderson
Jan 27, 2015 08:30 AM
Jan 23, 2015 01:13 PM
