Anyone have detailed insructions on taking the dash apart?
Old Sep 7, 2002 | 03:13 PM
91RS5speed's Avatar
Post Anyone have detailed insructions on taking the dash apart?
I had 2 bulbs burn out in my dash. One behind the speedo and the other is the fuel and oil pressure. How much do i have to take apart to do this?
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Sep 8, 2002 | 11:37 AM
citizendan1st's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by 91RS5speed:
</font>
its not hard...first take a torque screw drive nad take al the nuts out of the black plactic cover,then take a little nut driver to remove the clear plastic cover...you should have access to those bulbs with really skinny fingers or a thin long needle nose pliers.
ive replaced mine a few times.
takes half an hour.
just dont break the bulbs taking them out.
and i suggest doing them all at once too.
hope this helps,
Dan
Old Sep 8, 2002 | 02:44 PM
91RS5speed's Avatar
Post
I was looking into it and I cant get the pull out light switch apart. How do I do it without destroying it?
Victor Lamb
Aug 26, 2017 02:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
Brake_L8
Jan 20, 2015 09:44 AM
Darth Xed
Jul 1, 2002 03:22 PM
