annoying misfire. can anyone help?
Old Dec 8, 2007 | 08:18 PM
sn8ke eatr's Avatar
my winter beater car is a 92 camaro rs, with an automatic and a 305(tbi). the other night i was driving and it was running fantastic, but it was less then 20 degrees out and the motor never passed 150 degrees. on most days, the motor reaches about 180 degrees, the service engine light comes on, and it begins to run ****ty. it misfires, and hesitates, sometimes almost enough that i think the engine will stall. it feels horrible. since it seems heat related i think its something electrical that is messing up when it gets hot. does anyone have any suggestions or has had this happen to them?
Old Dec 9, 2007 | 09:35 AM
Dave89IROC's Avatar
can you get your hands on a scanner? look at the ECT reading
also, failing ICMs and coils can be heat sensitive as well
Old Dec 9, 2007 | 12:56 PM
sn8ke eatr's Avatar
a fried of mine has a scanner that works for a 97lt1, he sai dwith a differnt program it will work on my car too so if i cant figure it out maybe ill buy that. i was thinking coil as well. would the stock coil out of an lt1 work on a tbi motor? they look the same.
Old Dec 9, 2007 | 05:24 PM
Dave89IROC's Avatar
Originally Posted by sn8ke eatr
a fried of mine has a scanner that works for a 97lt1, he said with a differnt program it will work on my car too so if i cant figure it out maybe ill buy that. i was thinking coil as well. would the stock coil out of an lt1 work on a tbi motor? they look the same.
if they look the same, yes
cristian1311
Sep 12, 2015 08:16 PM
Boss002
Jul 24, 2015 10:47 AM
Noenav
Apr 30, 2015 01:06 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
DubbyZ28Camaro
Jan 13, 2003 03:21 PM
