Alum vs. Stock Driveshaft??
Old Apr 30, 2006 | 03:59 PM
staleyracing's Avatar
Arrow Alum vs. Stock Driveshaft??
I was wondering if anyone had any input on the kinda Horsepower I would be freeing up with using a aluminum driveshaft on my L98. Thanks
Old Apr 30, 2006 | 07:40 PM
Re: Alum vs. Stock Driveshaft??
cool thanks
Old May 1, 2006 | 07:00 AM
LesPaulGoth's Avatar
Originally Posted by Gunny Highway
It's better to finish everything else up first though. It's one of those things that your $150 could be better spent towards something else. Just a thought . . .
Agreed, it's always a good idea, but I would put that money into the motor first. That is where you will make your real power.
Old May 1, 2006 | 08:04 AM
teke184's Avatar
but something like an ls1 driveshaft will eliminate alot of added vibration at highway speeds.
another Pro of swapping it out.
and it's more like 1-2hp and 5#s of torque
Old May 1, 2006 | 08:24 AM
I didnt spend 150.00 on it. Its outta a LS1 car Ive noticed less vibration at 100mph. I didnt get a chance to take it any higher..ran outta room..too much traffic I paid less then 80.00 for it and Im pretty happy with it cause that old stock driveshaft weighed a ton compared to this baby.
Old May 1, 2006 | 10:23 AM
krazzycowgirl's Avatar
I have a LPE alm driveshaft in my car & no vibration on it. My husband also has one as well in his 95 Camaro no notice in there.
Old May 1, 2006 | 04:02 PM
Gord's Green Z28's Avatar
How do you tell if vibration is from your tires or from your driveshaft?
Old May 1, 2006 | 10:12 PM
Zepher's Avatar
I would like to know as well since I have a massive vibration at about 90mph.
I've got the stock aluminum Driveshaft on my 88.
Old May 1, 2006 | 11:23 PM
Ditto for me too Zepher. Only seems to happen at high RPM. A bit through the end of 2nd gear and really noticeable going through 3rd gear. (automatic)
3.27 gears, original tires, 1LE shaft.
Old May 2, 2006 | 03:51 AM
iansane's Avatar
Go have your wheels/tires balanced and see if that fixes it?
Old May 2, 2006 | 02:25 PM
Zrunner90's Avatar
That would be a good start probably. i would think a tire vibration would be felt through the steering wheel more, and a driveshaft vibration would be felt more through the seats and floor.
Old May 4, 2006 | 04:53 PM
1991l98g92's Avatar
General rule of thumb for tire vibration:
Felt in the steering wheel - front tires
Felt in the seat - rear tires.
Old May 4, 2006 | 05:11 PM
1987IROC350's Avatar
I have a lot of vibration in my car. I put on new tires, struts and shocks and the vibration only reduced a little. I'm going to an aluminum driveshaft soon. Is it a good idea to get a used one off a '99 or earlier 4TH gen????? Or should I spend the money on a new one????? I heard that Chevy had a recall on the early 1993 driveshafts due to vibrations.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
wytblur
Jul 19, 2002 10:26 PM
