Alternates toTPIS Mini-Ram???
I have a 406ci SBC long block ready to go and a looking for an alternate to the TPIS Mini-Ram. At this point I prefer the same short runner design but am open to any thoughts. Thanks for any replies.
Holley Stealth Ram. Very nice piece that will easily support the demands of your big inch small block
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Mike L.
OR a modded LT1 intake.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28
Superramed roller 406 10.5 compression, AFR 195's and custom cam.
future mods:
N20 waiting to be installed
Wifes new car:
1995 Z28
AT, leather, T-tops bone stock for now. 250 RWHP 300 RWT 14.0 @ 99 MPH on a 2.2 60'
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone (maybe)
1983Z28
future mods:
Wifes new car:
1995 Z28
future mods:
Modded LT1 intake is what gets my vote. I have a Mini Ram, but if John had been doing LT1 intakes before I bought the Mini Ram - I'm positive I would have bought a modded LT1 intake instead.
My other choice would be a converted 4bbl carb intake. That is what I initailly wanted for my car, but I got talked out of it.
1986 IROC-Z, 8pt. cage, 383, Mini Ram, DFI, Art Carr 700R4, 12 bolt.....
Edelbrock Victor Jr. Drilled and tapped to use 8 fuel injectors
..adapt some fuel rails and tune away!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Denny Villemure
www.denny.cz28.com
Thanks for the input guy's. I'll be looking into the Holley (didn't know they made one). Any pictures of how the LT1 is modified? I may be running an Electromotive TEC II so don't need to modify for a distributer, just the coolant outlet and ??? (bolt holes?)
I have a converted Hilborn with 2 1/8" butterflies but it's just a little to wild for my 87 El Camino. (You have to live with a high idle.)
Thanks again for the info.
www.lt1intake.com
1983Z28
future mods:
Wifes new car:
1995 Z28
future mods:
1983Z28
future mods:
Wifes new car:
1995 Z28
future mods:
I would go sky high, of course that's what I'm doing. Nothing flows like a 4 barrel single plane intake. get one with a fuel injector bosses and get a plenum adapter and a throttle body. doing some running around in Accel DFI adobe online catalog. Look at page 233 that is what you can make. Part number # 74139 (intake) part # 74882 (adapter) and a TB of your choice, rpm range 1,500-7,000 and you just can't go wrong
Kevin
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Kevin
Mods;
ntimad8.cz28.com
tommalcolm
Sep 11, 2015 03:39 PM
