ALL MOTOR and No more computer or electric
Old Jun 25, 2004 | 10:17 PM
autobotirockz88's Avatar
I have a 305 carborator v-8. Everytime I turn around there is something going wrong with computer, the censors/relays, wiring, it goes on and on. I even had to pay gm $300 smacks for a new cooling sensor! I just want to know if its possible to stripp all the annoying computer censors and have just a motor like the old days! Get rid of all the emissions too! ALL MOTOR and No more computer or electrics? I was planning on striping everthing but the ac/heat, and radio. I was going to replace the computer guages with a mechanical classical design by covas classics. So what I need is a run through of what all I need to do, to achieve my goal? THANKS!
Old Jun 25, 2004 | 11:44 PM
thezisking's Avatar
You'd have to put a non-computer controlled carb on it for one...
Old Jun 26, 2004 | 02:02 AM
jconrad's Avatar
The first thing you will need is a vacuum advance distributor. Most Chevy trucks had them from 70's to mid 80's. Most likely that same truck will have your carb too, but you can run the CC carb w/o the TPS and MC hooked up until you find another carb.
I did this and quite a few other mods to my old 83 S/E LG4 with no problems.
As far as eliminating all the sensors, well about the only things the ECM can control is the fuel/air mixture, and the advance of the distributor. So by swapping those 2 parts, you are defeating the computer control.
Hope this helps.
BTW, if you haven't already, get rid of that air pump too. The caps you will need are 1/2" pipe caps
DirtyDaveW
Mar 15, 2015 07:01 PM
Jan 5, 2015 07:14 PM
Jazsun
Dec 29, 2014 12:14 PM
