AFR Heads
Old Apr 14, 2004 | 01:40 PM
WhiteKid's Avatar
AFR Heads
Im looking to get some AFR heads. What size can I go with on my stock TPI 350? I want to get the 180cc or the 195cc. Im going to have Comp Cams make me a custom cam for the heads. What should I consider for fuel? Bigger injectors bigger pump? Anything else? Thanks
Old Apr 14, 2004 | 02:02 PM
mako350Z28's Avatar
Change your intake. The TPI will not be able to take advantage of the bigger cam or better flowing heads.
Old Apr 14, 2004 | 07:59 PM
aklim's Avatar
I'd go 195 so when you change your intake, it will make it work better.
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
95maroboi
Jun 7, 2015 12:18 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
