AFPR going in, question about fuel pressure
Old Nov 13, 2003 | 11:48 PM
dj haf's Avatar
for best performance, where should i set the fuel pressure at? i heard 45 psi from some people, but i wanted to get some more opinions. i want to get the best performance from this at WOT, thanks guys
Old Nov 14, 2003 | 12:34 AM
AutoRoc's Avatar
Fuel Pressure is like Timing really. Every car has different needs and optimum performance has to be found by testing and tuning. Choosing a dyno or a track is up to you and so is a good way of recording data, etc to track performance as a whole. Starting where you're already at is the way to go. If it's 45 PSI, that should be cool. Stock was usually from 38-45 I think. Adding 2 PSI to see if there is a gain or loss, dropping 2 psi to see if there is a gain or loss, dropping 2 more, adding 2 more, 4 more, 10 more. Same goes for timing. Try 6 degrees, then 7, then 8, 10, 11, 12, 15, etc. Goodluck. Taking your time to do all of this WILL pay off. No car is spot on after 10-20 years of service and tinkering.
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
