92 Camaro RS cranks even with key removed!
Old 11-15-2018, 11:34 PM
  #16
Re: 92 Camaro RS cranks even with key removed!
Starter could be pulling excessive amps. Not sure if the auto shop checked that. More amps means more voltage loss between the battery and the starter. Low voltage means slow cranking. Corroded terminals, corroded wires also increase voltage loss. Check both ends of the main cable from the battery to the starter, and the engine ground straps. Missing engine ground straps can increase voltage loss.
Injuneer is offline
Old 11-16-2018, 08:39 AM
  #17
Noah.reine's Avatar
Thanks for the tip. I知 going out today to go over the engine grounds. I know the starter wires are all good on both ends as well as the ground wire from the battery.
Noah.reine is offline
cyteone
03-12-2011 10:01 PM
matLT1
07-14-2009 07:25 PM
L.A. Z
03-12-2004 01:53 PM
Aaron '95 T/A
02-26-2004 03:59 PM
Quick Reply: 92 Camaro RS cranks even with key removed!
