92 305 TBI to TPI swap
Old Apr 25, 2005 | 07:11 AM
Slow91z's Avatar
What all is needed to do this swap??
Also to complicate the matter we're thinking about using an older 2 pcs. rear main 355 with trickflow heads and a healthy cam, and a holley stealth ram intake.
Do the TBI and TPI car's use the same computer?? Do we need a TPI ECM or will a chip change work?? What about the harness?? any sensors interchange between the TPI and TBI??
Thanks for any and all help fellas, this is going in a 5 speed car also just to let you know.
Old Apr 25, 2005 | 06:40 PM
fbodyfreak's Avatar
Re: 92 305 TBI to TPI swap
You will definately need the harness, chip and ecm. They say if you use a harness from the same year you wont have to make any modifications to it, but im not sure about that.
Old Apr 25, 2005 | 06:43 PM
Black305RS's Avatar
im doing this now
instead of listing it all here go to www.thirdgen.org in the tech articles theres an article on this.
its quite a bit but its doable
Old Apr 25, 2005 | 11:27 PM
Slow91z's Avatar
Originally Posted by Black305RS
im doing this now
Thanks Black that was quite helpful.
Any other input will be welcomed.
Boss002
Jul 24, 2015 10:47 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
