88 iroc not starting
Old Aug 16, 2004 | 02:26 AM
1bad88's Avatar
i need help with my 88 iroc it is not starting, it doesnt even attempt to start its like the battery is dead but its shows a full charge on my charger, any help! please, fast
Old Aug 16, 2004 | 10:01 AM
aklim's Avatar
Re: 88 iroc not starting
If it is not turning over and you have a full charge, check the starter. Rap it a little and see if it helps. If it does, you need a new starter. Also, make sure the contacts are clean. There is a wire going to the starter that is purple, not to be confused witht he battery cable. When you turn the key, you should get 12V at that point. Make sure you do. If you do, then it is either the starter or bad positive cable.
Old Aug 16, 2004 | 01:43 PM
RedIrocZ-28's Avatar
Lookm at the dash and see if the Security light stays on. If it does your VATS system has gone out and you need to either take it to a dealer and have $300ish worth of deaer only parts put on OR, you're gonna have to disable it manually.
dale3in98
Feb 14, 2015 12:18 PM
dawg irocz
Feb 10, 2015 10:33 AM
Amshnock
14
Jan 18, 2015 11:47 AM
capebuf
Jan 13, 2015 07:22 PM
