87 Iroc-z
Old Jan 9, 2003 | 10:17 PM
oakland raiders's Avatar
87 Iroc-z
I have a friend who got a 87 IROC-Z TPI 350 automatic transmission.... what do you guys recommend to have this engine puttin out sum horses??can you guys give some insight?? He has about six hundred dollars to work with...... thanks in advance
Old Jan 10, 2003 | 12:47 AM
Chris Ja's Avatar
Eternal Member
I would start with the free mods. Throttle body coolant by pass and gut the air filter box. I would do the lower control arms and panhard bar. A little traction goes a long way. If it doesn't have a air foil and K&N filter I would do those. If it doesn't have a aftermarket cat back do those. A electric cut out is good. Those should get you into the mid to low 14.
Old Jan 10, 2003 | 01:05 AM
stonedchihuahua's Avatar
I see you found the site... if you don't know what coolant bypass is it is basically bypass the tbi coolant system (might be hard to start if the car ever sees snow)
Old Jan 10, 2003 | 01:33 AM
krazzycowgirl's Avatar
Mid 14s are easy to get at just by changing the Chip, Adding an airfoil, Cutting the bottom of the airbox off & adding K&Ns
Heres a site that you can do a homemade Ram air system that no one would know about until you tell them. http://www.thirdgen.org/newdesign/tech/ramair.shtml
Old Jan 10, 2003 | 01:48 AM
thanks for directin me here stonedchihuahua this is a good site.........
Old Jan 10, 2003 | 07:12 AM
Jim85IROC's Avatar
I would skip the air foil. For some reason everybody around here seems to like them, but the air flowing through the throttle body is FAR from the largest restriction that the air will encounter. The runners are such a restriction that an air foil on the throttle body is virtually useless. A stock throttle body can flow enough air to feed an LT4, so it's going to have no problems feeding your L98.
Anyway... I agree that traction is a good idea. Another good idea is headers, high flow cat and a catback exhaust. That alone will eat up the whole $600 budget, but it's a necessity if you plan on doing more mods later.
Old Jan 11, 2003 | 05:53 AM
Yeah wish I could help ya more though... I don't know too much about fuel inject... maybe it is cuz I hate it or maybe that is the reason I hate it so much
Old Jan 11, 2003 | 10:46 AM
Z28ROC's Avatar
Gut the air boxes, with K&Ns. Headers and catback. Low temp fan switch, sticky tires, higher stall, port the plenum and siamese the runners. You can't do all this for $600, but it gives you some options
Old Jan 11, 2003 | 12:03 PM
I EAT T/A's Avatar
Cool
I like your purge valve placement. Sweet!!!
Old Jan 11, 2003 | 02:05 PM
Z28ROC's Avatar
Thumbs up
Old Jan 11, 2003 | 04:26 PM
jd13's Avatar
Some headers and a catback. Really wakes the car up, plus you get a nice exhaust note too. That'll pretty much eat up your money, but do the free mods other insisted also.
Old Jan 11, 2003 | 05:47 PM
aklim's Avatar
Accel Superram Intakes will help plenty. Biggest restriction is in the intakes.
irocbob89
Aug 15, 2002 12:53 AM
Rage
Aug 8, 2002 11:24 PM
Rage
Aug 8, 2002 02:47 AM
Rage
9
Aug 7, 2002 08:08 AM
