87 Iroc value
Old Jun 23, 2002 | 08:27 AM
panther's Avatar
Question 87 Iroc value
I have located a 1987 Iroc with a 5.7, t-tops, auto, and 55,000 miles. Originally I was under the impression that it was in running condition, but I was told that it's not due to a flywheel problem. The owner took it in to have the converter worked on and the shop didn't tighten the flywheel bolts down properly. Doesn't sound like a big deal though. Also, it is in need of a paint job, 15 years of summer driving takes a toll I guess.
Now, the good. The interior is spotless. Pretty close to showroom for a 1987.
I have been told to come back Wednesday and make a offer. I don't want to low ball them in anyway, just get a fair deal. What is low mile 350 Iroc, not running, needing paint worth?
Any input would be greatly appreciated.
Old Jun 23, 2002 | 08:29 AM
panther's Avatar
Post
Also, is there anything to look for knowing that the flywheel wasn't tighten properly. Could anything else been screwed up that I should take into consideration?
Old Jun 23, 2002 | 09:52 AM
IROC5.7TPI's Avatar
Post
First off, unless theres documentation to support the miles on the car I'd assume that they're 155,000 on a 15 year old car.
I bought mine in the same exact condition for $1300. It ended up needing a transmission
Look at the link in my sig to see how far its come. After paint and a bunch of mods I have over $5000 in it and still have lots to do.
Good luck.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Old Jun 23, 2002 | 10:52 AM
panther's Avatar
Post
Yeah Mike I thought about the miles. However being from Michigan also, 155000 would mean winter driving for sure. 10,500 miles/year without would be very hard. Looking under the car, there is no evidence of winter driving. Radiator supports aren't rusted, inside rockers, nothing. So, my assumption is 55k is 55k. The car is owned my a older gentleman that no longer wants the car.
You said that you needed a transmission. Were there any signs before you bought the car, or only after it died? Over the winter, I would plan on having the trans and rear end rebuilt stronger anyway, but the cheaper I can get the car, the better.
Old Jun 23, 2002 | 03:47 PM
IROC5.7TPI's Avatar
Post
I bought mine from the 2nd owner and have every receipt from every nut and bolt replaced on the car and records of storage and maintenence. Every year in storage November 1st and back out around the middle of April. Also there were checklists from when it went in and out of storage. Mine has 160,000 miles on it and was NEVER winter driven. Look at it now and it looks like it has 60,000 on it.
Looks can be deceiving.
Mike L.
Mods:
Old Jun 24, 2002 | 01:08 AM
Sitting Bull's Avatar
Post
Those low mileage Camaros are still around, amazingly enough! I saw one recently on www.thirdgen.org. It was an 86 Iroc with 2700 miles on it! No kidding. You should see all the pics the guy posted. He bought it new and has basically kept it in his garage in Florida ever since. It still has EVERY grease mark from factory inspection on it and the plastic seat covers.
We all drooled.
Old Jun 24, 2002 | 09:29 AM
Jim85IROC's Avatar
Post
So the car doesn't run and needs paint. $1,000 sounds like a fair offer.
BTW, chet's 2,700 mile IROC is phenominal!!
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
Old Jun 26, 2002 | 06:09 PM
panther's Avatar
Post
Well, it looks like i'll continue to look. I stopped by tonight and was told they were thinking in the neighborhood of around $6500/obo. They would fix it before it is sold but once it's running it needs another $3000 or so in paint/bodywork. It also really needs a set of tires. Add it all up and it becomes a $10000 car. No way!
Old Jul 1, 2002 | 01:32 PM
bcirocz's Avatar
Post
Hey Sitting Bull whats the name of that car at third gen's site? Love to take a look at it. As you said Drool (mmm collectors item)
As for the 87 Iroc. I find it kinda weird that a car with 55000 miles is having flywheel problems. If it were me i wouldnt offer more than 1200 cause new paint and transmission work is big bucks. (Never do one of those cheap *** paints, youll regret it later)
Matt Dreessen
Sep 9, 2015 09:58 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Pestilence
Aug 18, 2015 06:19 PM
