4th gen brakes on a 3rd gen
Old Dec 12, 2003 | 05:04 PM
dazedandconfused's Avatar
Does anyone know if it is possible to adapt the 4th gen brakes to a 3rd gen camaro? I was looking through the summit mag. and noticed a 6 piston brake upgrade for the 4th gens. I would love to have this set up. Are there any fellow 3rd genners with a big brake up grade that can share what they are using?
Old Dec 12, 2003 | 05:54 PM
TheGreatJ's Avatar
It's possible....and it's been done. There are a few guys over on TGO who have gone to 98+ brakes and Eric (LT1powered85Z) here was the first I know of to make the swap. I have a deal pending on a full set of 98+ brakes to go on my RS as well.
You should visit the suspension board at thirdgen.org.....there are quite a few threads there about various brake upgrades, and one about those 6-piston calipers specifically.
Old Dec 12, 2003 | 08:24 PM
Dave89IROC's Avatar
For my 89 IROC, I am doing C4 front brakes and 4th gen rear disks, so, anything is possible
Old Dec 13, 2003 | 08:45 AM
Chuck!'s Avatar
If you have a crappy non-posi 2.73 drum rear like I did, you can get posi, 3.42's and LS1 rear discs by swaping in a rear out of a 98+ fbody. Now my rears are about the same size as the fronts, doh!
Old Dec 15, 2003 | 12:14 AM
Zepher's Avatar
One of my friends just put the 98+ rear brakes on his 86 Z28 today.
It seemed like a pretty easy affair. e-brake cables need to be changed or adapted. I think he is going to try the 91-92 1LE cables and see if they work.
I did it the easy way, just put the entire rear end from a 99 SS onto my car.
Old Dec 15, 2003 | 07:12 AM
dewey316's Avatar
I have C4's on my car, they fit my factory 15's
the LS1 brakes are basicly the exact same process as the C4's, the only diffrence is really the caliper, it is the same floating PBR design, but the reinforcement fins are larger, and will not clear without at least a 16" wheel (not sure if it will fit the thirdgen wheels or not). the basic process is this, you turn a set of factory rotors down on a lathe, so they can be used as hubs, you then modify your spindle to 1le specs. then you have to fab caliper mounting brackets.
pics of my setup can be seen here....
http://www.cardomain.com/memberpage/314283/2
Old Dec 15, 2003 | 07:48 AM
shanebang76's Avatar
I swapped in a borg warner 89' 3.45 rear and it has the SAME rear brakes as my nieghbor's 95 T/A. Bigger than my front rotors!!
Old Dec 15, 2003 | 09:43 AM
Chuck!'s Avatar
Zepher, do you have any pics of how you got the ebrake cables to go onto the calipers and what cables you used?
Old Dec 15, 2003 | 04:18 PM
Zepher's Avatar
On my car, I am using the 98+ e-brake cables, but I haven't hooked them up to the equalizer or the e-brake handle yet. They are just hanging around under the car at teh moment.
The stock cables for the non-pbr rear disc brakes won't work since those cables have the small log style ends and the 98+pbr uses the cable with a slotted end.
I don't have any pics of the cable ends on the computer.
Old Dec 16, 2003 | 03:01 AM
ebmiller88's Avatar
I presently have C4s on my RS but will be installing the LS1s soon and see what they're like. Pics in the links:
C4s:http://f1.pg.photos.yahoo.com/ph/tar...m/taramiller72
LS1s:http://f1.pg.photos.yahoo.com/ph/tar...m/taramiller72
Ed
ChrisFrez
Mar 22, 2015 07:00 PM
Jul 4, 2005 05:00 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
