455 CID in a 3gen ...possible?
Old Dec 14, 2004 | 10:44 AM
Unix's Avatar
Sup guys !
I need some help, real fast... i'm thinking about buying a 455 ci. big block (used to be in a Buick Electra) , is it possible to mount such an engine in a 3gen Camaro ? Will it fit in the engine compartment ? Maybe someone has done this before?
thanks guys!
Old Dec 14, 2004 | 10:53 AM
speedingpenguin's Avatar
Re: 455 CID in a 3gen ...possible?
yep, it can be done, check this out
http://www.thirdgen.org/techbb2/show...hreadid=252874
Old Dec 14, 2004 | 02:30 PM
RedIrocZ-28's Avatar
Good luck. Thats all I have to say. I have seen a 400 in a 3rd gen. If a 455 is bigger in dimensions. Wow... good luck buddy!
Old Dec 14, 2004 | 02:37 PM
Tru2Chevy's Avatar
Whats the big deal about a 400 in a 3rd gen? They are the same size as a 305 or 350.
Here is my 400 in my '87 Camaro LT: http://www.njfboa.org/JustinImages/Mighty400.jpg
The 455 is a Buick/Olds/Pontiac motor, which (IIRC) is larger externally than a sbc, but smaller than a bbc. No problem as far as fitting it in a 3rd gen, but you will prolly need a cowl hood.
- Justin
Old Dec 14, 2004 | 09:11 PM
91chevyz28's Avatar
i've seen a guy at the track w/ a 455 buick in a 89 trans am
Old Dec 15, 2004 | 12:49 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Yeah it can be done, and for the record a 455 is not a big block, its a BOP block, they are all the same size (with the possible exception of the rocket I cant recall) you can put 326 heads on a 455 if you want.
At least I know pontiac blocks are
Old Dec 15, 2004 | 09:52 AM
OutsiderIROC-Z's Avatar
That is definitely cool. I have a friend who put a 455 Olds in a 79 Z28, and has thought about putting the same engine in his 86 Z28.
At one time I had a 455 Buick that I was considering putting in my 83 Firebird, but I did not have the time or resources to pull it off.
Old Dec 15, 2004 | 12:27 PM
Tru2Chevy's Avatar
Originally Posted by robvas
Will a BOP bolt up to a 700R4 or T5?
No, that pattern is different. You should be able to find an adapter plate though....
- Justin
Old Dec 15, 2004 | 07:31 PM
85_305's Avatar
Nope.. different bellhousing pattern I believe. I believe they require BOP tranny's.. but I am not positive.
Old Dec 15, 2004 | 09:51 PM
ws6transam's Avatar
FWIW, the hot ticket motor is either the '73 Cadillac 501 with ported 472 heads, or the '65 / '66 Olds 425 with 4V heads. fairly lightweight engines relative to the displacement, and the 425 has a superior rod/stroke ratio than the 455, PLUS a forged steel crank for nitrous use.
I saw a '91ish Mustang with a stock cadillac motor in it at the Hot Rod Magazine pump gas drags. It inhaled incredible amounts of nitrous and was faster than stink.
Old Dec 16, 2004 | 04:07 AM
Unix's Avatar
thanx for all the input ! I'm still wondering if i should put a 455 in my camaro, since it's my only car and daily driver...
anyway, if i do get this engine it'll go with a TH400 trans.
regards
Old Dec 16, 2004 | 04:21 AM
jay_lt4's Avatar
i had a 88 camaro that i put a pontiac 455 with a muncie 4 spd and 12 bolt rear end in, it didnt fit that bad exhaust is really tight, made a really fun daily driver
so yes it is possible
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Sep 14, 2015 02:02 AM
brand-x
Advanced Tech
Apr 2, 2003 01:06 PM
Smokeyz28
27
Jan 7, 2003 11:06 PM
cobra2550
V6 Tech
Oct 6, 2002 10:09 PM
