How do i fix a broken temp. guage?
Old Dec 15, 2004 | 08:04 AM
chamorro's Avatar
My temp guage stays all the way to the top, past the temperatures....(1 o'clock area) its been like that ever since i pulled it out of storage..(in arizona)....do i need to replace the temp guage, or the temp sensor, or is the needle just stuck?
Old Dec 15, 2004 | 10:44 AM
aklim's Avatar
Re: How do i fix a broken temp. guage?
Don't know what is wrong yet. Need more info.
What is the gauge like before you start the car or even get the key in?
Short out the temp sensor wire and see what the gauge says.
What car? What engine? What year?
Old Dec 15, 2004 | 12:18 PM
NJSPEEDER24
Guest
Posts: n/a
probably sending unit but need more info
Old Dec 15, 2004 | 02:52 PM
chamorro's Avatar
ok, its an 83 berlinetta with an LG4. the temp guage was always like that ever since i brought it out of storage. is there anything else you need to know?
Old Dec 15, 2004 | 04:20 PM
Rice Killer87's Avatar
does it stay like that even if u turn the key on and off?
Old Dec 16, 2004 | 03:49 AM
keopectake's Avatar
My 87z's got the same problem, someone told me to check my wires near the manifold on the driver's side.
Old Dec 16, 2004 | 08:44 AM
aklim's Avatar
If, without power, the gauge is still at that position, it is more than likely the gauge. If not, short out the temp sensor wire and you should see it go to red hot on the gauge. If that is the case then the problem is in the sensor.
Knightscrapper
Feb 4, 2016 10:25 AM
dylan1303
Aug 12, 2015 02:00 AM
2QUIK6
Jul 2, 2015 07:02 AM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
MislMan
Jul 19, 2002 11:41 AM
