400 small block
Old Mar 22, 2003 | 10:21 AM
Montty Garrett's Avatar
400 small block
I am building a 406 and my camaro has a T5 in it. What flywheel do I use with this? I an also thinking of goin to a T56, what flywheel for this one. I have tried may searches but havent found the answer. I know some body has put a 400 or 383 in there manual cars. This is a basic stock 400, just wanted the extra cubes.
thanks
Old Mar 22, 2003 | 11:28 AM
Aaron91RS's Avatar
well the 168 tooth 400 one won't fit inside a t5 housing.
Old Mar 22, 2003 | 12:28 PM
Black6SpdTA's Avatar
i dont know what flywheel to use but i have a question..a 406 is a 400 bored .030? right?
Old Mar 22, 2003 | 12:46 PM
sleepybu's Avatar
you need a 400 f wheel cuz there externaly balanced
Old Mar 22, 2003 | 01:25 PM
AndrewC's Avatar
flywheel
you do need the 400 flywheel for the external balance.
Old Mar 22, 2003 | 03:16 PM
ahotrod79's Avatar
yes.
And you need the externally balanced flywheel. There is a balance piece you can buy that you put on with a regular flywheel so you can use it with the 400, but if you are going to have to get another one to fit the T5 just buy one for a 400 that is externally balanced.
Old Mar 22, 2003 | 11:38 PM
stonedchihuahua's Avatar
Actually don't get the 400 flywheel, they are apparently alot of money and the balancing plate is like 35 bucks and it will allow you to use any sbc flywheel, this is a much better Idea because you can have the option of using alot more flywheels for different trannys and they are almost always cheaper.
Old Mar 23, 2003 | 10:45 AM
Thanks for the replys. So I need to get a balancing plate then I can use the original flywheel that was designed for the Trans. I beleived I saw one on Ebay so I will pick it up tonight. Thanks for all the great advice.
Old Mar 23, 2003 | 04:15 PM
insomniac 92z28's Avatar
I don't know if this will help but I know the LT1 T56 flywheels are externally balanced also.
geinsteder
May 6, 2015 06:02 AM
dpw21562
Apr 16, 2015 09:41 AM
ad356
Apr 11, 2015 08:49 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
