3.73 posi install , help!!!!
Old Mar 21, 2003 | 06:22 PM
AndrewC's Avatar
So I mulled it over and went and got the 3.73 posi. Now having said that. does anyone have a document on installing them and setting them up. My good friend says if they are too tight they explode, and if they are too loose they will wear fast. There is some kinda play that needs adjusting. He also said you need to mix posi fluid with the gear oil, does that make sence??? It's supposed to condition the oil for a posi setup........
Old Mar 21, 2003 | 08:03 PM
mr diabolical's Avatar
you gotta have special tools to install gears. your better off taking it to a shop to have it done professionally.
Old Mar 21, 2003 | 08:37 PM
TheGreatJ's Avatar
I agree.....if you haven't done it before it's not something to mess with. It's too easy to have a few thousandths too much shim and end up killing your gears after 4 months.
Old Mar 21, 2003 | 11:58 PM
AndrewC's Avatar
Question 3.73 posi carrier
Well i have the whole carrier complete can I not just install it all in one piece? there is really nothing to put together?
Old Mar 22, 2003 | 06:42 AM
87DJP2001's Avatar
Re: 3.73 posi carrier
If you set the pinion depth and have the correct backlash on the ring gear, you can install it. But by your posts, you don't know what you are doing and just assembled everything.
How if you think you know it all, just put the carrier assembly in the axle and say to yourself good job. Just take it for a test drive.
Old Mar 22, 2003 | 07:52 AM
Zepher's Avatar
To do it right, you have to put it together and take it apart a few times using different color marker to set the wear pattern.
My friend who does gears on the side for dealers and performance freaks like ourselves takes a couple of hours doing a rear to make sure everything is set right.
Best to have someone that knows gears show you how to do it, and if you get the hang of it, you can make some decent money doing it on the side.
Old Mar 23, 2003 | 04:25 PM
insomniac 92z28's Avatar
Guessing from your pics I assume you have a removable center section on your rear end, like a ford. If so you really don't need to set your lash since they are already installed in the center section. If not take it to a pro because it will not last long if it's not perfect.
Nov 18, 2023 07:21 PM
blac94Z
29
Mar 25, 2015 04:21 PM
TitoPR221
Jan 29, 2015 08:00 PM
DropTop91
22
Aug 8, 2002 10:53 AM
Smokn '94 Z
Aug 4, 2002 06:11 PM
