3rd gen tach problem
Old Jul 8, 2005 | 01:17 PM
Crovax WS-6's Avatar
SO i just picked up my 87 GTA last weekend. Tpi 350, and most of the little toys. The only problems i have discovered is that there is an exhaust manifold leak. Which is an easy fix. and My tahc is reading 1/2 of what it should when im on the throttle. At idle it sits at around 700-800, and it jumps a bit cause there is a misfire at idle. But when i get on teh gas and Pin it, it will never go over 3K. Is this an electrical problem thats an easy fix, or should i just swap the cluster? btw its got the 8K tach in it.
Old Jul 8, 2005 | 09:31 PM
89TramsAmGTA's Avatar
Re: 3rd gen tach problem
Does it have an MSD ignition? I had to get a tach filter for mine. Allen
Old Jul 9, 2005 | 05:26 AM
fade2blk500's Avatar
Check the wiring at the distributor, could be a gauge problem.
Old Jul 9, 2005 | 09:07 AM
no the car is almost totally stock, the only things it has are an exhaust and a shift kit. So i know its ntohgin aftermarket messin with the signal. IM thinkin it is prolly the cluster, but i was hopin it was something else.
mr28
Apr 20, 2016 05:44 PM
Zee man
Feb 12, 2015 07:07 AM
mr28
Nov 23, 2014 11:11 AM
19redta96
Jul 23, 2002 12:25 PM
