373 gears and shift kit??
Old Apr 24, 2003 | 10:11 PM
2FAST4YA's Avatar
I was thinking about going to 373 gears (I have 323's now) and getting a transgo shift kit, my question is will these items shave any time off my 1/4 mile time.
Thanks,
Old Apr 25, 2003 | 07:30 AM
irocz8957's Avatar
maybe a tenth or two tenths of a second but not a major change!
Old Apr 29, 2003 | 04:52 AM
Pro Built Automatics's Avatar
Keep the 3.23's and spend the money on a good 9.5" lockup torque converter (A.C.T. or Vigilante) instead, and you might pickup 3-6 tenths in the quarter mile.
Old Apr 29, 2003 | 07:18 AM
irocz8957's Avatar
pro bulit has the right idea you should keep the 323's and go with a nice tourqe converter
Old Apr 29, 2003 | 01:49 PM
89'Formula's Avatar
I say go with the 3.73 b/c of the superram pulling more HP than the stock TPI. If you had the stock TPI I would say stay with the 3.23. As far as the TC, unless you run slicks, I would say stay with the one you have otherwise traction will be more nonexistant! Sounds like a good combo, what do you run in the 1/4?
Old Apr 29, 2003 | 08:16 PM
aklim's Avatar
I'd go with the 3.73 gears.
How much life left in the tranny? You'd better pull the pan and check the mileage. You don't want to put on a new TC and have to change the tranny 3000 miles later, do you? If there is metal in the pan, I'd say the tranny is on the way out and you should wait to have it rebuilt before you put in a shift kit and TC. I usually condemn a TC if there are shavings in the pan because I am not sure if everything in the TC can be cleaned out without cutting it apart.
2FAST4YA's Avatar
Thanks for the input guys I'm still trying to decide, and so far i've been running low 14's 14.1, 14.2 with bad traction, personally I think I should be running better and I need someone to fine tune my car. What do you think abou those times?? I'm kind of new at this.
Old Apr 30, 2003 | 09:15 AM
aklim's Avatar
What are you doing for an EPROM? There was a big change when LPE reburnt my EPROM.
Your times seem decent for what you have done tho.
Old Apr 30, 2003 | 09:50 PM
2FAST4YA's Avatar
My system is setup as speed density, and I have a DFI setup where you use a laptop to tune your car.
armedtrigger
Feb 24, 2015 08:30 PM
jb4xx
Feb 2, 2015 10:00 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
