350 Motor swap
Old Oct 14, 2002 | 03:56 PM
purduetwinkie's Avatar
350 Motor swap
What is different about the 5.0 and 5.7 cars. I heard that 5.0 cars have no posi trac. What are the gears for both? Are there different driveshafts? How hard is the swap from 5.0-5.7 tpi and could you tell me a little about it. my email is bcmay@purdue.edu I would like to take a 5.0 rs convertable and drop in a 5.7 and everything else needed to make it as fast as a iroc.
Old Oct 14, 2002 | 06:19 PM
guywidiroc's Avatar
There are many more things to condsider. A simple 305 tpi swap to a 350 tpi only needs a few things like a new ecm. But if you are going from a carb 305 to a 350 tpi, you are going to need a lot more. And posi is an option that had nothing to do with engine size....I believe its G80 or something.
Old Oct 15, 2002 | 09:01 PM
eddie123456's Avatar
Yes Its not to bad Just did it for a buddy.
If you have 305 tpi You can swap out to a 350 no prob.
You will need a new prom, for the ecm 40 bucks from GM.
And it helps if you get a later 350 87 and up.
everything else bolts right up.
Old Oct 15, 2002 | 10:13 PM
Cool it sounds as if I just need a tpi 350 and computer or prom and everything hooks right up. What else is needed to make the rs an 5.7 iroc?
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
transam_388
Mar 15, 2015 11:53 AM
Chris Anderson
Jan 27, 2015 08:30 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
