305HO help
Re: 305HO help
just be sure to take the cap off the distributor and mark where the rotor is pointing to be sure u get it back in the right spot.
yes 350 heads can go on a 305,but it will drop the compression and prob. run like ****.
good luck
good luck
Re: 305HO help
Originally Posted by ugly84Z28
I am looking to put an Edlebrock intake and Holley 650 on my 305. Any advice or issuse I need to be aware of? Also will 350 heads work on a 305?
thanks
ugly
thanks
ugly
Yes, DON'T DO IT!!!!!!
It will provide nothing over what you already have. Go here and read the tech articles on tuning your QJet. http://www.thirdgen.org/newdesign/tech/
It is a GREAT street carb and your stock intake manifold is certainly good enough until you replace your current exhaust (headers all the way to the tailpipe), heads and cam--in that order.
For the best deal on heads just port and polish your current ones! Follow the link at the end of my sig.
Re: 305HO help
What part should I not do? Carb or intake or both??
What about some headers? What would you recommend?
I read the article on the Quadrajet and made some adjustments and seems to run a little bettter....thanks
If i decide not to put the intake and Holley on I'll sell it and make some money. lol
Later
Ugly
Later
Ugly
