305 TBI cooling system
Old May 4, 2005 | 11:07 PM
brians96Z's Avatar
Question 305 TBI cooling system
I flushed my cooling system on my 90 RS 305 TBI. My question is, how do I know there are no air pockets? I didn't find any bleed screws anywhere on this thing, did they not have them?? It is not overheating, but it still bugs me not knowing if there are air pockets. What do ya'll think?
Old May 5, 2005 | 02:15 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: 305 TBI cooling system
Run the engine with the radiator cap off until it gets warm. Then the thermostat will open and coolant will circulate throughout the engine. Let it run like that for 10+ minutes, then stop the engine and check the coolant level in the radiator. Add more if necessary.
Old May 5, 2005 | 09:20 AM
brians96Z's Avatar
Thanks Kevin, I'll try that!
Old May 5, 2005 | 09:40 AM
teke184's Avatar
i think the reverse cooled design of the LT1 makes it more important to bleed the system.
just the standard method described above should suffice for your engine
Old May 5, 2005 | 12:42 PM
Black305RS's Avatar
the only cars that MAY have airbleeds are cars where the radiator is lower than the engine. so the thirdgen does not have one and leavng the radiator cap off isnt neccesary the air will leak out of the overflow tanks by itself while you drive.
Old May 6, 2005 | 03:01 AM
Damon's Avatar
These older engines in 3rd gens are pretty much self-bleeding of any air pockets. Once the stat opens any remaining trapped air pockets clean themselves out.
I do it just like Kevin describes. I just don't feel satisfied until I've properly "burped" my cooling system. When the stat opens you get a big rush of coolant and air for a second or two and then it settles down and all is normal at that point. Add coolant as necessary to top it off after you "burp" it.
Magenta_Hearts
Mar 25, 2015 10:24 AM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
