305 tbi to 305 tpi question
Old Apr 25, 2008 | 06:23 AM
Uc360's Avatar
i have a 1988 firebird formula 350 with a 305 tbi and a 91 camaro with a 305 tpi my questions are would the firebirds 5 speed mount to the 305 tpi engine?, it is a borg warner 5 speed, and can i use the automatic computer out of the camaro for the firebird, even though it is a 5 speed, and will the firebirds wiring harness pin up to the sensors on the tpi??
Old Apr 25, 2008 | 10:29 AM
1987IROC350's Avatar
I confused. So your wanting to swap fuel inj. systems and transmissions from one to the other.
Also since Formula 350's only came with L98 and the 700R4 I must assume the Formula rear is the stock BW 7.65 9 bolt.
I thought BW only made rears, not trans. But I'm not sure about that. What is the 5 speed out of?
I don't see why the computer would not work going to a 5-speed.
Old Apr 26, 2008 | 08:58 AM
87DJP2001's Avatar
Just swapping 305 engine is no problem and will mate up with the 5sp. You will need the TPI wiring hardness. The ECM can also be switched over, however it will need a new prom for the conversion to work. One question. You state Formula 350, so what is it??? A Formula with a stock TBI.
Old Apr 26, 2008 | 10:18 AM
Tex95Z's Avatar
On the $$
F'n1996Z28SS
Aug 23, 2023 11:19 PM
STR FTR 1
Feb 10, 2015 10:36 PM
Amshnock
14
Jan 18, 2015 11:47 AM
hotrod 5210
Dec 22, 2014 07:28 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
