305 performance?? can i run high 14's
I have a 88 camaro with a tbi 305 and a turbo 350 tranny, I know the engine isn't much but what can i do to make it run high 14's without changing displacement or getting a cam?
Re: 305 performance?? can i run high 14's
headers ,intake , carb all these are cheap and easy bolt on performence building parts a nice set of headers can bump you from 195hp to 225hp a raised intake will give you better high end power and a good carb will help to support it but you only have 195hp if you have a g engine ...if you have a h block then you only have right around 150hp
get some gears out back and a stall for that TH350. Create some high end power to use the gears... like said, raised intake and a good carb and get your exhaust setup w/ lots of flow and you should see good times.
pull the heads, cam, intake, injection, etc, well if you're going that far might as well drop in a 350 then. the TBI 305 heads suck, you could get some 305 TPI heads, port them and add 1.94 valves to them and put in a bigger cam as well. definately headers and a 3" catback
- Justin
Here is what my 89 305 TBI motor had and ran consistant 14.8s.
Open Element
Hedman Headers
Flowmaster
Posi, 3.23 gears
A.I.R. delete
305 TPI heads ($40 complete)
Ultimate TBI mods
LT1 cam
This 305 ran hard and never missed a beat. In 1-2 days work you can also have a 14 sec 305 TBI. The heads and cam were the hardest part and even they werent HARD. Good luck.
Open Element
Hedman Headers
Flowmaster
Posi, 3.23 gears
A.I.R. delete
Ultimate TBI mods
LT1 cam
With the following I've turned a 14.2. It could do better with out the autocross suspension setup.
SR Torquer 305 heads
Performer Intake
LT1 cam
Headers and exhaust
Open element air cleaner
8 degrees advance on timing
Custom prom tuning
Stock TBI
AC and AIR delete
3.42 gears and posi
It's dynoed 225 rwhp.
Performer Intake
LT1 cam
Headers and exhaust
Custom prom tuning
Stock TBI
AC and AIR delete
3.42 gears and posi
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
