305 performance?? can i run high 14's
Old Feb 14, 2005 | 03:57 PM
streetheatz28's Avatar
Thumbs up 305 performance?? can i run high 14's
I have a 88 camaro with a tbi 305 and a turbo 350 tranny, I know the engine isn't much but what can i do to make it run high 14's without changing displacement or getting a cam?
Old Feb 14, 2005 | 04:04 PM
jer's Avatar
jer
Re: 305 performance?? can i run high 14's
headers ,intake , carb all these are cheap and easy bolt on performence building parts a nice set of headers can bump you from 195hp to 225hp a raised intake will give you better high end power and a good carb will help to support it but you only have 195hp if you have a g engine ...if you have a h block then you only have right around 150hp
Old Feb 14, 2005 | 05:56 PM
colin911's Avatar
305 TBI's never had 195hp. I think 88's were about 170
Old Feb 14, 2005 | 07:54 PM
JSkeet's Avatar
get some gears out back and a stall for that TH350. Create some high end power to use the gears... like said, raised intake and a good carb and get your exhaust setup w/ lots of flow and you should see good times.
Old Feb 14, 2005 | 09:14 PM
xpndbl3's Avatar
pull the heads, cam, intake, injection, etc, well if you're going that far might as well drop in a 350 then. the TBI 305 heads suck, you could get some 305 TPI heads, port them and add 1.94 valves to them and put in a bigger cam as well. definately headers and a 3" catback
Old Feb 15, 2005 | 12:41 PM
Tru2Chevy's Avatar
Some simple motor bolts ons (intake, headers, full exhaust), a custom tune, and good car prep will easily put you into the 14's.
- Justin
Old Feb 15, 2005 | 12:58 PM
89305rs's Avatar
Here is what my 89 305 TBI motor had and ran consistant 14.8s.
Open Element
Hedman Headers
Flowmaster
Posi, 3.23 gears
A.I.R. delete
305 TPI heads ($40 complete)
Ultimate TBI mods
LT1 cam
This 305 ran hard and never missed a beat. In 1-2 days work you can also have a 14 sec 305 TBI. The heads and cam were the hardest part and even they werent HARD. Good luck.
Old Feb 15, 2005 | 12:59 PM
89305rs's Avatar
BTW the gears made the biggest difference in NOTICABLE power.
Old Feb 15, 2005 | 01:02 PM
Tru2Chevy's Avatar
89305...did you ever get your car tuned?
Custom tuning can make a huge difference in the way a TBI car runs.
- Justin
Old Feb 15, 2005 | 01:18 PM
89305rs's Avatar
No, that was with no tune on it whatsoever. The only thing was that it idled a little rough. Man you could feel the cam come in at around 2500 RPM.
Old Feb 16, 2005 | 12:10 PM
axoid's Avatar
With the following I've turned a 14.2. It could do better with out the autocross suspension setup.
SR Torquer 305 heads
Performer Intake
LT1 cam
Headers and exhaust
Open element air cleaner
8 degrees advance on timing
Custom prom tuning
Stock TBI
AC and AIR delete
3.42 gears and posi
It's dynoed 225 rwhp.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
