305 G block
Old Mar 7, 2004 | 11:52 PM
Eric88XJ's Avatar
305 G block
Are 305 G blocks worth anything? What are the differances between a G and say a regular 305? I tried the search, bugt G is too short of term to search on. Any info would be appreciated!
Old Mar 8, 2004 | 01:49 PM
Marc 85Z28's Avatar
G block? As in the 8th digit of the VIN, engine code G?
That's the L69 engine. AKA 305 H.O. It was produced from 1983-1988 and could only be had in the Z28, Formula/Trans Am, and the Monte Carlo SS. I don't believe the block is any different, however the camshaft is a little stronger than the standard LG4, or H code engine. The heads should be the same, as well as the rods and crank. The compression ratio on all L69 engines was 9.5:1, and only the later 85+ LG4 engines got the 9.5:1 ratio. Earlier LG4s had only 8.6:1.
The L69 made a significant amount more power than the LG4. Ratings were around 45 more HP depending on year. The cam played a good part, but the rest was in manifolds and tuning.
Do a search for L69 and you'll come up with all the specifics you need.
Old Mar 8, 2004 | 10:51 PM
Eric88XJ's Avatar
On what would be the right rear of the engine, if you were standing in front of it, is the cast 5.0L G then the casting number of the block. The casting number says it is an 86 block that had a 4bl on it. It had a TPI setup on it when I bought it, the numbers come back as an 85 TPI setup. Thanks for all the info! Much appreciated.
Tarizza
Sep 20, 2015 03:26 PM
heus
Sep 8, 2015 12:01 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
