305 5.0 TPI in 94 camaro
Old Dec 5, 2004 | 09:48 PM
keithystealmaro's Avatar
Talking 305 5.0 TPI in 94 camaro
Hey do u 3rd gen camaro owners think it would be a good idea for me to stick a 305 5.0 TPI into my 94 v6 camaro??? I think it has like 190 horse and 285 lbs torque?
Old Dec 5, 2004 | 10:20 PM
82355's Avatar
Re: 305 5.0 TPI in 94 camaro
I think it would be funny to see. Not very feasible, but funny to see.
Martin
Old Dec 5, 2004 | 10:49 PM
Andrew R's Avatar
Lightbulb Re: 305 5.0 TPI in 94 camaro
Well, at least your not yanking out an lt1 for the 305
Putting in a 305 TPI in the v6 car might make it slower
Old Dec 5, 2004 | 10:59 PM
Kwiksilverz28's Avatar
Just get an LT1. The TPI distributor will require mods to the firewall.....
Old Dec 6, 2004 | 07:20 AM
axoid's Avatar
The only time I've heard on someone doing this was because they were building an SCCA American Sedan race car which has a 5 liter limit.
Old Dec 6, 2004 | 09:04 AM
305RSlc's Avatar
Do yourself a favor and just get an LT1 and forget about doing a typical SBC in a 4th gen. I could only imagine the grief you'd be facing the first time you went to change your dist. cap. Not to mention, you'd need to modify the firewall to make it fit in the first place. Besides, a LT1 outpowers any factory tpi engine made.
Old Dec 8, 2004 | 09:51 PM
MY91Y84's Avatar
that depends on the 305 you put in it...the G92 LB9 was 230hp and 300 ft pounds..this was with the 5 speed with the L98 cam and 3.42 gears
mine ran 14.12@96 with minimal mods...but i also drove the **** out of it..a stock LT1 will trap 99-101
Old Dec 8, 2004 | 10:11 PM
ws6transam's Avatar
Nope. I dont think it would be a good idea due to the clearance issues. You probably wouldn't be able to close your hood, you wouldn't be emissions legal, and the wiring issues would be trouble.
Best plan is to plop in an LT1 which would probably be about the same amount of money, and a whole lot less labor.
Old Dec 13, 2004 | 01:36 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
It doesnt work. The TPI intake & distributor will not fit under the cowl of the 4th gen. I know because someone I know tried it.
Old Dec 15, 2004 | 09:37 PM
Talking Re: 305 5.0 TPI in 94 camaro
forget it i guess it was a stupid idea i just had the engine sitting in the garage and dont know wut to do with it but forget the lt1 also! I am going for the LS1! hehhhe
Old Dec 16, 2004 | 01:53 AM
camaroz28racer2's Avatar
Try going for the LQ4/9
F'n1996Z28SS
Aug 23, 2023 11:19 PM
92ragtop
Dec 27, 2014 01:56 PM
hotrod 5210
Dec 22, 2014 07:28 AM
CaRParts102
Dec 6, 2014 08:45 AM
