2.8 ?
Old Aug 13, 2003 | 04:12 PM
camaro9402's Avatar
2.8 ?
is there anything i can do to my 2.8 to make it more peppy other than put a new engine in it can someone help thanks
Old Aug 13, 2003 | 05:00 PM
kevin 2.8's Avatar
you can, but i wouldnt. its not a very good $ to benifiet . i have the 2.8 fi
id do just free stuff like exhaust cut out and gut cat,
other than that you could spend the same $ on another camaro.
the fastest 2.8 ive heard on this board was 15.9sec 1/4
forget who it was but he said
/quote
Rebuilt Tranny with Shift Kit at firmest level, Corvette Servo 2000RPM Stall
MSD Coil
Accel Wires
No Spare Tire
No Floor Mats
No car audio stuff like HU or box
Hurst Dual Gate Shifter set in D not OD
NO TB Coolant lines
NO MAF Screen
Ported upper plenum (home done)
Custom Intake I made with PVC and Conical
Fastr Chip by Ed Wright Stage 2
Synthetic Oil
Stock AC Delco Plugs changed yearly
Rear tires at 21PSI
Front at 42PSI
Dynomax Cat Back Exhaust
Catco High Flow Conv
you should also check out this page, some guy twin turboed a 2.8 gm motor in a 500 datsun
doesnt have any #'s but im guessing over 300hp
http://www.bryanf.com/mycars/510V6.htm
also check out some 2.8 - 3.4 swap threads, you dont need much more than the block to do that swap, you can use almost all the 2.8 motors hardware & acc.
-kev
sodak86
May 24, 2015 03:54 PM
KRS
May 16, 2003 04:37 PM
FattMarrell
Apr 5, 2003 03:24 AM
darkoverlift
Mar 12, 2003 01:42 PM
oil pan 4
V6 Tech
Nov 23, 2002 02:11 AM
