1992 Camaro Transmission/clutch problem
Old Dec 23, 2003 | 05:20 PM
Ville H. Valo's Avatar
Big problem, i will be driving and randomly i will lose almost all power, it is easy to tell that the clutch is slipping, but it was recently replaced, also, i recently bleed the clutch. anyways, it will go out, i will stop for a minute and then it will be fine again. do i need a new clutch or what?
1992 Camaro Z28 5.0 5 Speed
Old Dec 24, 2003 | 12:54 AM
Hydralic
I was told this evening that it might be the hydralics in the transmissions, any input would be great.
Old Dec 24, 2003 | 01:43 AM
90rocz's Avatar
That's a tuffy, a lot of things could've went wrong on the clutch job...but there's a good chance the master/slave cylinder is bad..
Not that hard to swap, and should'nt be too expensive.
You might see about getting a free estimate at a tranny place, then decide where to go from there.
Old Dec 24, 2003 | 01:54 AM
Master Cylinder
that would cause it to diengauge and then it would work properly? i think the Hydralic arm sounds more resonable, but thanks for the input i will ask a tranny place
Old Dec 24, 2003 | 02:27 AM
90rocz's Avatar
The problem is, the clutch is hydrolicly adjusted, master/slave cylinders...The internals of the trans has nothing to do with it..
Red Hawk 94
Mar 18, 2019 04:03 PM
92ragtop
Dec 27, 2014 01:56 PM
bernie1951
Dec 10, 2014 10:03 AM
siguy
Nov 27, 2014 10:07 AM
Chrisdude
Jul 24, 2002 02:25 PM
