180 thermostat does it affect performance?
Old Sep 4, 2002 | 08:48 PM
ratdog's Avatar
Question 180 thermostat does it affect performance?
I was recently told that it could affect perfomance on my 84z,??? what are the pro's & con's,is it worth installing.THANKS
Old Sep 4, 2002 | 09:26 PM
91RS5speed's Avatar
Post
It makes a differance. I think for every 10 or 20 degrees cooler your engine is you get like 1hp or so. Running at a cooler temature will alow you to run more timing also. Which will also get you more hp.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Sep 5, 2002 | 01:41 PM
jd13's Avatar
Post
There really aren't any downsides to running cooler, granted that everything else is right.
Old Sep 5, 2002 | 08:25 PM
napa dude's Avatar
Post
fwiw most 180 degree thermostats open at 195 degrees. and most 195 degree thermostats open at 212.so it would make you engine run cooler
willismoons
May 27, 2015 04:03 PM
thenewkid
Apr 12, 2015 07:42 PM
HCz28
Feb 15, 2015 03:01 PM
thenewkid
Nov 27, 2014 09:41 AM
